8 Beta Tool bar
Where can I download Rhino 8 toolbars, if I go to C:\Users\cadgu\AppData\Roaming\McNeel\Rhinoceros\8.0 There is no UI file folder. If I go to check in C:\Program Files\Rhino 8 WIP I cannot find the toolbars. Where can I download the RUI toolbars for Rhino 8
Toolbars are different in V8 than the previous version due to the re-envisioning of the UI towards a more modern and cross platform one.
The “Toolbars” are objects hosted by “Containers” and the containers are managed as subcomponents of workspaces (Window Layout) , you can configure your UIs and back it up or shared as rhw. using Window > Manage Window Layouts.
also, rhino saves the UI Settings under xml files, I suggest not to play with them unless you know what are you doing:
%AppData%\McNeel\Rhinoceros\8.0\Plug-ins\Toolbars (dc297053-96c0-4883-a688-8326b4e024a8)\settings
%AppData%\McNeel\Rhinoceros\8.0\settings
