Rhino 8 Sweep 2 won't show Isocurve Preview!
When I use the Sweep 2 command in Rhino, the Isocurves don’t preview. Therefore I can’t add a Slash where I want to because I can’t see what Isocurves to fix.
BUG!_Sweep 2 No UV Preview.3dm (246.8 KB)
There is a problem with your file.
I copied the lines and pasted them into a new file. It worked normally.
Your file works as expected for me.
Run the Rhino command SystemInfo and post the results.
