Hello all,
This is a quick note for Rhino 8 UI. Overall the UI has been much more compatible with Windows’ “High Contrast” theme, and therefore more accessible. However, in the startup Window it seems to convert the text to white and leave the window white, making everything unreadable. This has been an issue in Rhino 7 and you can still navigate blindly through it, but it’s a bit inconvenient. Screenshots below.
Best,
Paul
