Rhino 8 ScriptEditor file tabs window feature missings
Hi @eirannejad,
if you open more files in the ScriptEditor than fit in the file tab window size, you can do this, but you cannot access these files directly. You have to resize the window or close files on the left side of the window.
In other editors you can find different solutions, either you find right left file buttons or drop down lists to the select files that are outside the current window width.
hi @daniel.kowollik you can browse through the tabs with the scroll wheel on your mouse. But having a list in Window makes sense.
RH-84935 Access list of open documents
Hi @Gijs,
thank you for the quick response and creating a task out of this feature request.
@daniel.kowollik Currently you can scroll your mouse over the tabs. I will get the feature request implemented as well.
RH-86545 is fixed in Rhino WIP
