- I know that there is an old topic, but rendering far from origin is still with problems. Keeping base point should be a must in models. Suggested to implement a variable that controls the area that the program uses to compute the model.
- How to stop batch render views without taking the Rhino down? If something is detected at render start, that seems to be the only way for when the process begins.
Thank you. Coming from Autocad, each day Rhino love is increasing.
Hit esc several times, it should cancel the rendering and the batch rendering.
(Rhino in Mac) I tried that… just loads the next view. The problem is that the model is large and the meshes do not load fast in order to do esc again.
Once the render window is up you press esc. That cancels the render, and that in turn will cancel the batch rendering of named views.
I just tested that on my Mac.
I was trying to close the render window to stop the render, not pressing esc. Tried just now and it worked. Thank you!
