Similar to how you can change print width per layer and layout print width, is there a way to change custom section styles for layout? I’m working with Rhino 8 clipping sections to create different layouts. I have the same detail in different scales on different layouts. In one detail, I would like to maintain the custom section style I’ve assigned to that layer (e.g. a simple 45 degree hatch). In another detail that’s a larger scale, I would like to change the section style (e.g. wood grain hatch) for the layer just in that detail or just for that layout. Is there a way to do that?
Also, is there a way to select multiple details and change what display style they are at once? I find that when I use the “technical” display view, my Rhino gets super laggy in layout. I’d like to print using the “technical” display mode, however, I want to work in a different display mode for efficiency.
