Rhino 8 Layer State disables Model On
When I activate a Layer State, Rhino is turning off the Model On setting for layers which are not selected by the Layer State. In order to activate other layers manually after activating a Layer State, I have to activate each impacted layer, then reactivate the Model On setting. This is new behaviour. There does not appear to be a Model On setting in the Layer State scope settings, so I cannot think of anything that I might have accidentally changed.
Version 8 (8.30.26069.02002, 2026-03-10)
Regards, Garry.
ModelOn.3dm (11.3 MB)
Update…
This is not a problem on Rhino for Windows. It works correctly, so it is a Mac related issue.
Regards, Garry.
Hey Garry,
I’m trying to repeat your issue with your file and I’m able to go back and forth between the layer states with no issues. Am I missing a step?
@Japhy After activating a Layer State, try to activate the layers which have been turned off by the Layer State. The layers show as active, but their objects do not display until you also activate Model On.
Regards, Garry.
Got it. Thanks for reporting RH-94104 Layer State change disables ability to turn on/off layer
@Japhy I just noticed that this behaviour is no longer occurring. I looked at RH-94104 and read your comments. Clearly whatever was amiss has been corrected. Regarding the question from @dale it was the corruption / deactivation of the Model On setting by the activation of a Layer State that was causing the problem. Corruption gone, so problem solved. You probably want to close the YT report.
I am now on Version 8 (8.34.26215.11002, 2026-08-03).
Regards, Garry.
