Rhino 8 Display issue
Hi, I’m experiencing an issue with object display in Rhino 8. Please see the video below.
Has anyone encountered the same problem?
If so, what is the best solution to resolve it?
Below, I have attached my system information:
Rhino 8 SR26 2025-12-15 (Rhino 8, 8.26.25349.19001, Git hash:master @ c6182b1b71af690bf339ed38f9ccfc2fec2e46c3)
License type: Educational, build 2025-12-15
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9323.0
**Non-hybrid graphics configuration.
Primary display and OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-11-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.59
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port 1
  • Windows Main Display attached to adapter port #2
    Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-11-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.59
  • Windows Main Display attached to adapter port #2**
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2025
Driver Version: 32.0.15.9159
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.5.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.26.25349.19001
BR,
Adi
This doesn’t look like any problem with your GPU driver. It looks like a component in Grasshopper is not properly updating the viewport’s bounds when drawing its preview geometry. Please share this GH definition and we can try to get this tuned up.
Hello Steve,
Sorry for the late response.
Thank you for the clarification. Understood that this is likely related to a Grasshopper component not updating the viewport bounds correctly.
I have tried to uninstall all the plugins, including the VisualARQ. And it seems the issue is still.
Rhino 8 Display Issue.gh (2.6 MB)
Appreciate your support.
Best regards,
Adi Prayugo
Hi Adi -
This is a different issue. I’ve added this sample to RH-87912 Grasshopper: Display of FFO Points
Your original video looks simple enough, but I can’t reproduce that behavior here in a quick test. If you could add the .gh file for that issue, I can take a closer look.
Hi Wim,
Thank you for the quick response.
The first issue has been resolved by reinstalling VisualARQ and Rhino 8. However, I’ve attached the Grasshopper definition containing VisualARQ components for you to check
Best regards,
Adi
VisualARQ - Gh Definition.gh (4.8 KB)
RH-87912 is fixed in Rhino 8 Service Release 33
Thanks Brian and the Team for fixing the issue
Your support is greatly appreciated :blush:
