Hey there,
I am seeing some odd behavior with Gumball. Occasionally it does not center properly on the selected object. Here is an example. gumball off-center.3dm (2.5 MB)
The green curve on the left is the parent in a Linear Array. It is the only curve which Gumball accurately centers on. When any other curve is selected, the Gumball centers on the parent curve instead of the selected curve. The curve on the far right is a Copy of the curve #4 from the Linear Array, which also been moved in +x (with Gumball). When Selected, the gumball is positioned at the parent curve + moved x distance.
Hi Mike- I think is is fixed - I can’t find the bug report right at the moment for some reason but I am pretty sure it has been fixed - in any case it is correct here in our latest - what SR are you using?
Hi Mike - see if it is fixed for you in the SR candidate for SR7 - change update frequency in Options > Updates and Statistics page to ‘Service release candidate’
