Rhino 8 and Unity 6 connection
I am trying to use Rhino Inside (Rhino 8) in a Unity 6 project, starting from the template described in rhino.inside/Unity at rhino-7.x · mcneel/rhino.inside · GitHub.
To update everything, I needed to several additional dll’s to the project:
Microsoft.VisualBasic
System.Collections.Immutable
System.Reflection.Metadata
System.Runtime.CompilerServices.Unsafe
However, the compilation still fails with the following error:
Loading assembly failed: “Assets/RhinoInside/Microsoft.VisualBasic.dll” reason: File does not contain a valid CIL image
This exact same problem was reported here some time ago:
But since there was no reply, I wanted to ask if this this Rhino / Unity workflow is still supported?
Dag Tiemen -
The Rhino Inside Unity project was just a technology demonstration that others could use to build upon.
As you can see from the GitHub page that you linked to, one of the prerequisites was Unity 18.3. The Rhino WIP at the time was Rhino 7. This is likely going to need a bit of work to function for Unity 6 and Rhino 8.
I am also currently trying to implament this connection and i dont seem to find something more relevant for the latest versions of unity and rhino
Hi!
I know it’s been a little while since you posted this, but I wanted to bump the thread and ask if you (or anyone else here) ever found a reliable way to get Rhino 8 and Unity 6 working together smoothly?
I’m currently looking into this connection myself. I haven’t run into the specific DLL error yet, but I want to make sure this workflow is still actively supported before I dive too deep. My ultimate goal is to use Grasshopper for parametric modeling and push those models into Unity for AR visualizations.
If anyone has any updates, new workarounds, or recommended templates for the latest versions of both software, I would absolutely love to hear about them. Thanks!
