I’ve tried a number of times to update my Rhino 7 WIP with no luck.
NetFx48Redist:-2147019796
C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041.log
[4948:47C8][2020-08-31T08:00:41]i001: Burn v3.11.100.14911, Windows v10.0 (Build 10586: Service Pack 0), path: C:\Users\timlo\AppData\Local\Temp{D745DB44-9784-44C6-82C0-5490C4B3CC7A}.cr\rhino_en-us_7.0.20238.17095.exe
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘BundleVersion’ to value ‘7.0.20238.17095’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘CUSTOMER_NAME’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘COMPANY_NAME’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘INSTALLDIR’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘LICENSE_METHOD’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing hidden variable ‘LICENSE_KEY’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing hidden variable ‘LICENSE_VALIDATION_CODE’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘ZOO_SERVER’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘DISABLE_INTERNET_ACCESS’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘SEND_STATISTICS’ to value ‘1’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘RegistryRoot’ to value ‘Software\McNeel\Rhinoceros\7.0\Install’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing string variable ‘FolderName’ to value ‘Rhino 7 WIP’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_EN’ to value ‘1’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_FR’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_IT’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_DE’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_ES’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_KO’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_JA’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_TW’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_CN’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_PL’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_CS’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_PT’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i000: Initializing numeric variable ‘INSTALL_RU’ to value ‘0’
[4948:47C8][2020-08-31T08:00:41]i009: Command Line: ‘-burn.clean.room=C:\ProgramData\McNeel\McNeelUpdate\DownloadCache\ef42cb906bce90dc644e4f612ea1a6e4\7.0.20238.17095\rhino_en-us_7.0.20238.17095.exe -burn.filehandle.attached=456 -burn.filehandle.self=468 /passiveexceptrestart’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\ProgramData\McNeel\McNeelUpdate\DownloadCache\ef42cb906bce90dc644e4f612ea1a6e4\7.0.20238.17095\rhino_en-us_7.0.20238.17095.exe’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'C:\ProgramData\McNeel\McNeelUpdate\DownloadCache\ef42cb906bce90dc644e4f612ea1a6e4\7.0.20238.17095'
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041.log’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleName’ to value ‘Rhino WIP’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Robert McNeel & Associates’
[4948:47C8][2020-08-31T08:00:41]i100: Detect begin, 21 packages
[4948:4878][2020-08-31T08:00:41]i000: OnInitializeLayout
[4948:4878][2020-08-31T08:00:41]i000: PrivateDetect Begin
[4948:4878][2020-08-31T08:00:41]i000: NoCapabilitiesfalse1Rhino 6 Commercial0001-01-01T00:00:00Cloud Zoo LicenseTim Lopes - timlo@malibuboats.comfalsePEWsQ49p4yIt9889FIkEmP4Zo5Dif3tZ_TQgeLjsLpE0001-01-01T00:00:00Release145b1949-8ec2-4933-ab6a-fc384bc62fa8155500d41-3a41-4474-99b3-684032a4f4df55500d41-3a41-4474-99b3-684032a4f4dfCloudZooMcNeel Cloud ZooAvailable01[4948:4878][2020-08-31T08:00:41]i000: Detected CloudZoo license
[4948:4878][2020-08-31T08:00:41]i000: PrivateDetect End
[4948:4878][2020-08-31T08:00:41]i000: Setting hidden variable ‘LICENSE_KEY’
[4948:4878][2020-08-31T08:00:41]i000: Setting string variable ‘CUSTOMER_NAME’ to value ‘’
[4948:4878][2020-08-31T08:00:41]i000: Setting string variable ‘COMPANY_NAME’ to value ‘’
[4948:4878][2020-08-31T08:00:41]i000: Setting string variable ‘INSTALLDIR’ to value 'C:\Program Files\Rhino 7 WIP'
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘SEND_STATISTICS’ to value 1
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value 1
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘DISABLE_INTERNET_ACCESS’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_EN’ to value 1
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_FR’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_IT’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_DE’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_ES’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_KO’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_JA’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_TW’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_CN’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_PL’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_CS’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_PT’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: Setting numeric variable ‘INSTALL_RU’ to value 0
[4948:4878][2020-08-31T08:00:41]i000: GetSystemDefaultLangID() returned 1033
[4948:4878][2020-08-31T08:00:41]i000: GetUserDefaultLangID() returned 1033
[4948:4878][2020-08-31T08:00:41]i000: GetOsLanguage() returned en
[4948:4878][2020-08-31T08:00:41]i000: version_NT64 = 10.0.0.0; service_pack =
[4948:4878][2020-08-31T08:00:41]i000: Comparing ver_64 (10.0.0.0) to ver_win_81 (6.3.0.0)
[4948:4878][2020-08-31T08:00:41]i000: ver_64 !< ver_win_81
[4948:4878][2020-08-31T08:00:41]i000: Showing UI from C:\Users\timlo\AppData\Local\Temp{C424AB25-F9C2-415B-986C-BB27FCBBE28F}.ba\en\progress.htm
[4948:47C8][2020-08-31T08:00:41]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘10.0.10586.162’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘NETFRAMEWORK45’ to value ‘394806’
[4948:47C8][2020-08-31T08:00:41]i000: Setting version variable ‘BrokenUpgradeVersionDetected’ to value ‘6.30.20238.13311’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘ReadDisableInternetAccess’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘VC2010_exists’ to value 1
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NOT INSTALLDIR’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NOT COMPANY_NAME’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘COMPANY_NAME’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘VC2015_build’ to value ‘28508’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NOT ZOO_SERVER’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i000: Registry key not found. Key = ‘SOFTWARE\McNeel\Rhinoceros\7.0\License Manager’
[4948:47C8][2020-08-31T08:00:41]i000: Unsetting variable ‘ZOO_SERVER’
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘VC2013_exists’ to value 1
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘ReadDisableInternetAccess’ to value 1
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘VC2013_version’ to value ‘12.0.30501.0’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NOT SEND_STATISTICS’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NOT CUSTOMER_NAME’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘CUSTOMER_NAME’ to value ‘’
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘VC2015_exists’ to value 1
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘ReadEnableUpdatesKey’ to value 1
[4948:47C8][2020-08-31T08:00:41]i000: Setting numeric variable ‘VC2005_exists’ to value 1
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘VC2010_build’ to value ‘167812379’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘ReadEnableUpdatesKey’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘VC2005_build’ to value ‘134278728’
[4948:47C8][2020-08-31T08:00:41]i102: Detected related bundle: {1039cda1-de1e-4d69-a37b-315e365bb90a}, type: Upgrade, scope: PerMachine, version: 7.0.20231.16005, operation: MajorUpgrade
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘VC2005_exists=1 AND VC2005_build>=134278728’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘VC2010_exists=1 AND VC2010_build>=167812379’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘VC2013_exists=1 AND VC2013_version>=v12.0.30501.0’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘VC2015_exists=1 AND VC2015_build>=27827’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘NETFRAMEWORK45 >= 528040’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i103: Detected related package: {279981C6-CEF5-4F47-A071-D3C6023F2C6E}, scope: PerMachine, version: 7.0.20231.16005, language: 0 operation: MajorUpgrade
[4948:47C8][2020-08-31T08:00:41]i103: Detected related package: {195EAD75-61F1-48BD-B512-D55F7BB96930}, scope: PerMachine, version: 7.0.20231.16005, language: 0 operation: MajorUpgrade
[4948:47C8][2020-08-31T08:00:41]i103: Detected related package: {4CECE906-1510-4843-A575-A4EADF0A1EB1}, scope: PerMachine, version: 7.0.20231.16005, language: 0 operation: MajorUpgrade
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: Redist_VC2005, state: Present, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: Redist_VC2010, state: Present, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: Redist_VC2013, state: Present, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: Redist_VC2015, state: Present, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: NetFx48Redist, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: UninstallRelatedProducts.exe, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: rhino.msi, state: Absent, cached: Complete
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: rhiexec.msi, state: Absent, cached: Complete
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: en_lang_pack, state: Absent, cached: Complete
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: fr_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: it_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: de_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: es_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: ko_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: ja_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: tw_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: cn_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: pl_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: cs_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: pt_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i101: Detected package: ru_lang_pack, state: Absent, cached: None
[4948:47C8][2020-08-31T08:00:41]i199: Detect complete, result: 0x0
[4948:47C8][2020-08-31T08:00:41]i200: Plan begin, 21 packages, action: Install
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2005
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2010
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2013
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: Redist_VC2015
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: NetFx48Redist
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘NetFx48RedistLog’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_000_NetFx48Redist.log’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘BrokenUpgradeVersionDetected<v6.9.18262 AND LICENSE_METHOD=“ZOO” AND ZOO_SERVER<>“”’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]w321: Skipping dependency registration on package with no dependency providers: UninstallRelatedProducts.exe
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleRollbackLog_rhino.msi’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_001_rhino.msi_rollback.log’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleLog_rhino.msi’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_001_rhino.msi.log’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleRollbackLog_rhiexec.msi’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_002_rhiexec.msi_rollback.log’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleLog_rhiexec.msi’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_002_rhiexec.msi.log’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_EN=1’ evaluates to true.
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleRollbackLog_en_lang_pack’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_003_en_lang_pack_rollback.log’
[4948:47C8][2020-08-31T08:00:41]i000: Setting string variable ‘WixBundleLog_en_lang_pack’ to value ‘C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_003_en_lang_pack.log’
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_FR=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_IT=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_DE=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_ES=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_KO=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_JA=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_TW=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_CN=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_PL=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_CS=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_PT=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i052: Condition ‘INSTALL_RU=1’ evaluates to false.
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: Redist_VC2005, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: Redist_VC2010, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: Redist_VC2013, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: Redist_VC2015, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: NetFx48Redist, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: UninstallRelatedProducts.exe, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: rhino.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: rhiexec.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: en_lang_pack, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: fr_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: it_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: de_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: es_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: ko_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: ja_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: tw_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: cn_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: pl_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: cs_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: pt_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i201: Planned package: ru_lang_pack, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[4948:47C8][2020-08-31T08:00:41]i207: Planned related bundle: {1039cda1-de1e-4d69-a37b-315e365bb90a}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[4948:47C8][2020-08-31T08:00:41]i299: Plan complete, result: 0x0
[4948:47C8][2020-08-31T08:00:41]i300: Apply begin
[4948:47C8][2020-08-31T08:00:41]i010: Launching elevated engine process.
[4948:47C8][2020-08-31T08:00:43]i011: Launched elevated engine process.
[4948:47C8][2020-08-31T08:00:43]i012: Connected to elevated engine.
[45EC:4BB8][2020-08-31T08:00:43]i358: Pausing automatic updates.
[45EC:4BB8][2020-08-31T08:00:43]i359: Paused automatic updates.
[45EC:4BB8][2020-08-31T08:00:43]i360: Creating a system restore point.
[45EC:4BB8][2020-08-31T08:00:50]i361: Created a system restore point.
[45EC:4BB8][2020-08-31T08:00:50]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{270cade3-685f-434f-b0b2-11ad9083576e}, options: 0x7, disable resume: No
[45EC:4BB8][2020-08-31T08:00:50]i000: Caching bundle from: ‘C:\Users\timlo\AppData\Local\Temp{C424AB25-F9C2-415B-986C-BB27FCBBE28F}.be\Bootstrapper.exe’ to: ‘C:\ProgramData\Package Cache{270cade3-685f-434f-b0b2-11ad9083576e}\Bootstrapper.exe’
[45EC:4BB8][2020-08-31T08:00:50]i320: Registering bundle dependency provider: {270cade3-685f-434f-b0b2-11ad9083576e}, version: 7.0.20238.17095
[45EC:4BB8][2020-08-31T08:00:50]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{270cade3-685f-434f-b0b2-11ad9083576e}, resume: Active, restart initiated: No, disable resume: No
[4948:0714][2020-08-31T08:00:50]w343: Prompt for source of package: NetFx48Redist, payload: NetFx48Redist, path: C:\ProgramData\McNeel\McNeelUpdate\DownloadCache\ef42cb906bce90dc644e4f612ea1a6e4\7.0.20238.17095\redist\ndp48-x86-x64-allos-enu.exe
[4948:0714][2020-08-31T08:00:50]i338: Acquiring package: NetFx48Redist, payload: NetFx48Redist, download from: https://go.microsoft.com/fwlink/?LinkId=2088631
[45EC:46E8][2020-08-31T08:01:42]i305: Verified acquired payload: NetFx48Redist at path: C:\ProgramData\Package Cache.unverified\NetFx48Redist, moving to: C:\ProgramData\Package Cache\8DD233698D5EB4609B86C2AC917279FE39E0EF4C\redist\ndp48-x86-x64-allos-enu.exe.
[45EC:46E8][2020-08-31T08:01:42]i304: Verified existing payload: rhino.msi at path: C:\ProgramData\Package Cache{5FFDD673-371C-4BAE-B59B-B071F3C074DB}v7.0.20238.17095\rhino.msi.
[45EC:46E8][2020-08-31T08:01:42]i304: Verified existing payload: rhiexec.msi at path: C:\ProgramData\Package Cache{F9AABDC4-9D2A-41CD-B91E-DB6C5D8C05FF}v7.0.20238.17095\rhiexec.msi.
[45EC:46E8][2020-08-31T08:01:43]i304: Verified existing payload: en_lang_pack at path: C:\ProgramData\Package Cache{1375E995-D224-40B2-8AB3-602C8B882F4D}v7.0.20238.17095\redist\en-us\LanguagePack.msi.
[45EC:4BB8][2020-08-31T08:01:43]i301: Applying execute package: NetFx48Redist, action: Install, path: C:\ProgramData\Package Cache\8DD233698D5EB4609B86C2AC917279FE39E0EF4C\redist\ndp48-x86-x64-allos-enu.exe, arguments: ‘“C:\ProgramData\Package Cache\8DD233698D5EB4609B86C2AC917279FE39E0EF4C\redist\ndp48-x86-x64-allos-enu.exe” /q /norestart /ChainingPackage “Rhino WIP” /log “C:\Users\timlo\AppData\Local\Temp\Rhino_WIP_20200831080041_000_NetFx48Redist.log.html”’
[45EC:4BB8][2020-08-31T08:02:15]e000: Error 0x800713ec: Process returned error: 0x13ec
[45EC:4BB8][2020-08-31T08:02:15]e000: Error 0x800713ec: Failed to execute EXE package.
[4948:47C8][2020-08-31T08:02:15]e000: Error 0x800713ec: Failed to configure per-machine EXE package.
[4948:47C8][2020-08-31T08:02:15]i319: Applied execute package: NetFx48Redist, result: 0x800713ec, restart: None
[4948:47C8][2020-08-31T08:02:15]e000: Error 0x800713ec: Failed to execute EXE package.
[45EC:4BB8][2020-08-31T08:02:15]i351: Removing cached package: NetFx48Redist, from path: C:\ProgramData\Package Cache\8DD233698D5EB4609B86C2AC917279FE39E0EF4C\
[45EC:4BB8][2020-08-31T08:02:15]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{270cade3-685f-434f-b0b2-11ad9083576e}, resume: None, restart: None, disable resume: No
[45EC:4BB8][2020-08-31T08:02:15]i330: Removed bundle dependency provider: {270cade3-685f-434f-b0b2-11ad9083576e}
[45EC:4BB8][2020-08-31T08:02:15]i352: Removing cached bundle: {270cade3-685f-434f-b0b2-11ad9083576e}, from path: C:\ProgramData\Package Cache{270cade3-685f-434f-b0b2-11ad9083576e}\
[45EC:4BB8][2020-08-31T08:02:15]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{270cade3-685f-434f-b0b2-11ad9083576e}, resume: None, restart initiated: No, disable resume: No
[4948:47C8][2020-08-31T08:02:16]i399: Apply complete, result: 0x800713ec, restart: None, ba requested restart: No
Please save the error log to a text file and send that as an attachment.
We can run a file though our log analysis tool.
Thanks
Tim Lopes
Malibu Boats
(865) 657-6023 Direct Line
(209) 777-1512 Cell
[//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/mcneel/uploads/default/original/3X/0/2/0247cbf24ae35ebd3d16a4afbe513b80080b10b6.jpeg]
(Attachment Rhino_WIP_20200831080041.log is missing)
Possible Solutions:
- Cause: Failed to run a program included with the installer. The installer is trying to run a critical part of the installation process, but may be being blocked by antivirus or malware protection software.
Solution: Temporarily disable your virus scanner, then run installer again.
I am having the same issue with this NetFx48Redist package installing using -quiet command line.
It failed on installing on docker with image mcr.microsoft.com/windows:1809 (windows server 2019) but success on docker with image mcr.microsoft.com/windows:1903 (windows 10)
Logfile_failed_Rhino_WIP_7.0.20238.17095.zip (4.9 KB)
Attaching a success log file from previous WIP build.
Logfile_success_Rhino_WIP_7.0.20231.16005.zip (4.9 KB)
Rhino_WIP_20200831145033.zip (3.6 KB)
@Tim_Lopes - Rhino WIP to requires .NET 4.8. The installer should install this for you if necessary (from the log it looks like you have 4.6.2 installed) but last week’s installer had a bug that prevented this from working correctly. This bug has been fixed in the latest release from a couple of days ago, so please try again!
@t.ho - I’ve just published a new example Dockerfile that shows how to pre-install .NET 4.8 on an 1809 image before installing Rhino WIP.
Could you help me please, I can’t install rhino 7
Rhino_7_20210309111038.rar (3.9 KB)
I wish I could but I had to get our IT department to help with my . Our security software doesn’t allow non-authorized users to make certain changes to their work stations.
what is actually happening?
is there a log file?
if so, please send it to tech@mcneel.com
is windows fully updated? do you have an anti virus software that could be blocking the download of some critical installer components?
