Hi all,
I used Rhino 7 to generate a model for an underground mine. When I mesh the model, I found that it has 13 pairs of mesh faces that intersect each other. This mesh issue prevents me from exporting a valid mesh to a finite difference software to conduct a stress analysis.
Does anyone have any solutions to fix the mesh issue that I am having? test_2.3dm (16.8 MB)
Well that doesn’t really answer the question, does it ? I remember there was some kind of experimental command that allowed AT LEAST to spot the intersecting faces.
Can’t remember what crazy name it had though…
EDIT : found it !
TestCullClashingMeshFaces
Wouldn’t it make kind of sense to integrate this in the otherwise lamentable MeshRepair tool ?
By the way, you can see how much rigor was put in the command naming scheme when you discover there is a “RepairSubD” tool…
