What about the grain, @Gijs ? Is the grain being caused by my graphics card (Nvidia Quadro P2000) or is it something else? Speed is not that a big a deal for me – and I’m trying to decide whether to spend the money and get a better card. Would a better graphics card result in a sharper, better quality rendering?
Wow this image looks great @Gijs ! What do you mean by “automatically generated depth map”?
@cosmas tiny light sources will create more noise than larger ones in the same given time. A high dynamic range image with a bright sun will generate more noise than a lower dynamic overcast sky one.
Glossy materials will generate more noise than matte diffuse objects.
Etc. there are many factors affecting noise.
Your graphic card is not the cause of the noise, only affects speed. A newer /faster card will only make the rendering go faster and resolve the noise in a shorted amount of time.
Yes:)
I accidentally closed the previous, but here is a sample how it is set up
here you can see I am using the depth map as layer masks (sometimes inverted)
I am experiencing super grainy results with my AMD 5700 XT graphics card. I have the latest “pro” drivers v23.Q3 that are supposed to be more stable than adrenalin ones. I am using Rhino 7.32.23221.10241.
I attach the pixelated level of granularity below.
I am not sure why it happens for the standard views. When I select the Render button the renders don’t look bad at all on this separate Render dialog.
Hi Bartłomiej -
Note that this thread was originally about using the Render command, not the display in viewports.
Have you tried turning off GPU Tessellation in Rhino Options -> View -> OpenGL?
And, as for rendering…
Why not use the “Rhino Render”?
Thank you for trying to help. Unfortunately changing renderer (from Legacy to Legacy Rhino Render to Rhino Render), GPU tessellation setting does not improve the quality. The results are still very grainy. Does Rhino have some type of compatibility test suite I could run?
Hi -
I’m afraid I don’t know what that means.
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Educational, build 2023-09-05
License details: Cloud Zoo
Windows 11 (10.0.22622 SR0.0) or greater (Physical RAM: 48Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 5700 XT (AMD) Memory: 8GB, Driver date: 7-25-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 23.9.1.230719
> Accelerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 7-25-2023
Driver Version: 31.0.21018.5001
Z-Buffer depth: 24 bits
Total Video Memory: 8151 MB
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.38.3\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.3.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.24.4\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.24.4.0
C:\Users\amd\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.5.3\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.5.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
Can you offer any advice for my mac?
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16352, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational Lab License, build 2023-12-12
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Mac14,5
Language: en-US (MacOS default)
Apple M2 Max (OpenGL ver:4.1 Metal - 88)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M2 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M2 Max
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.36.23346.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.36.23346.16352
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.36.23346.1002
Hi Rita -
Is there a problem you are trying to solve?
