This might be redundant, but the last report appears to be 2021.
I consistently see Rhino 7 (7.31.23166.15002 currently running) continue to accumulate memory approximately linearly increasing even with no documents or windows open. This occurs regardless of command, display setting, foreground, or backgrounding of the application.
Steps to reproduce: launch Rhino 7. Open a new file. Close file, saving or not saving doesn’t appear to matter. Leave application running. Come back in a few hours, and the memory usage (as reported in Activity Monitor) is climbing into the GB. Leave for a day or so and it’s in the 10-50 GB range. Usually I notice this because when I go to open and work on a file, the spinning beachball appears. This is my cue to check activity monitor for a hilariously high number, quit and restart Rhino, and I’m back to normal.
What I would expect and wish to happen is the memory would be cleared, garbage collected, or otherwise purged when I close my last open file. Also I would wish that the spinning beachball never appears.
I will attache a blank document if that seems useful, but it is not model dependent for me.
Screenshot of activity monitor attached.
About Rhino > More Info result below.
Any suggestions appreciated! And thanks for all of your dedicated behind-the-scenes work! I’m very grateful.
Rhino 7 SR31 2023-6-15 (Rhino 7, 7.31.23166.15002, Git hash:master @ 850d276b2d59d7e51843939e4cf674b356bcd354)
License type: Commercial, build 2023-06-15
License details: Cloud ZooApple macOS Version 13.4 (Build 22F66) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,1
Language: en-US (MacOS default)Apple M1 Pro (OpenGL ver:4.1 Metal - 83.1)
OpenGL Settings
Safe mode: Off
Redraw scene when viewports are exposed: OnAnti-alias mode: 4x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: HighVendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1 Pro
Displays: Unknown (255dpi 2x)Graphics processors
Apple M1 Pro
Color LCD (1728 x 1117 @ 120.00Hz)USB devices
Apple Inc.: iPhoneBluetooth devices
NoneThird party kernel extensions
NoneThird party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/log/liblog_network.dylibRhino plugins that do not ship with Rhino
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.31.23166.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.31.23166.15002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.31.23166.1002
