Rhino 7 Crash with Climate Studio GH simulation
I have a problem induced by Climate Studio simulations. Each time I try a simulation, even a ‘light’ one with very low resolution, Rhino crashes. Yes my units are in m and not mm, and my resolution of my analysis grid is set to 2m. This is likely an issue with Climate Studio GH plugin specifically, since I can use it in Rhino and the crash ONLY occurs when I run a simulation from GH.
Please help!
Here’s my SystemInfo from Rhino post-crash:
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Educational, build 2020-12-08
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: Radeon Pro 555X (AMD) Memory: 4GB, Driver date: 11-21-2019 (M-D-Y). OpenGL Ver: 4.6.13570 Compatibility Profile Context FireGL 19.30.01.33 26.20.13001.33012
> Integrated acclerated graphics device with 7 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-21-2019
Driver Version: 26.20.13001.33012
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\SOFiSTiK\2020\SOFiSTiK Rhinoceros Interface 2020\sofrhino.rhp “SOFiSTiK Rhinoceros Interface 2020”
C:\Users\alexa\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
C:\Users\alexa\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.12.9.865\PanelingTools.rhp “PanelingTools”
Hello - I would contact the developer of that plug-in directly. In the meantime, your video drivers are quite old, I would update those to the latest available from the AMD website.
Trying to contact them, unfortunately they’re not the most responsive. I’ll try the driver update for AMD, thanks!
Also update your Rhino version. You’re still on Rhino 7.1, current service release is Rhino 7.6 (fixes made: Rhino 7 Service Release Available - #10 by brian, see the entire thread for all changes since your service release ).
