Rhino 6 WIP: PropertyListBox not working?
Hi @dale,
the PropertyListBox window from my Python script doesn’t popup in Rhino 6 WIP anymore. In Rhino 5 it works.
def TestPropertyListBox():
    items = [ 'Anchor x:', 'Anchor y:' ]
    values = [ 0.5, 0.5 ]
    results = rs.PropertyListBox(items, values, 'Add Object', "What should the object contain?")
# Check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if( __name__ == "__main__" ):
Any ideas?
Thanks
Michael
www.flexiCAD.com
Hi Michael,
this seems to work here on a slightly newer built than the current public one. Have tried this again after a restart of the WIP ?
c.
Hi Clement,
on the latest version (6.0.17143.8371, 23.05.2017) it doesn’t run here.
I will check with the next ones again. Thank you very much
Michael
www.flexiCAD.com
I’m also running (6.0.17143.8371, 2017-05-23) and that snipplet works fine here:
Hi wim,
thank you. I’ve tested it again, no PropertyListBox window shows here up under Windows 10.
Cheers
Michael
www.flexiCAD.com
