このライセンスキー「rh70-~」は有効期限が切れたため、バリデーションできません。
このようなエラーメッセージが出ます。対処方法をお願いします
You only get one trial. It is time to buy Rhino.
Hi -
As Jim wrote, you can only have one 90-day trial period.
In your case, that period hasn’t expired yet so there was no reason for you to try a new license key. Just use the first key that you received (ending on “00F2”) and you will be able to continue your trial period until February 1st. If you want to use Rhino after that date, you will have to purchase a license.
