RGB to Grayscale with ShapeDiverImageSampler
Hi everybody,
I am doing a shapediver definition, in which basically from an input image I would like to get the grayscale at locations. The ShapeDiverImageSampler component, returns colors in RGB format.
I am then wondering how to convert these colors in grayscale. I am thinking about splitting the returned list into a tree such that each branch (corresponding to a pixel) contains three items (R, G and B) and then use a formula (like L = 0.2125R + 0.7152G + 0.00722B) to convert the colors into grayscale. But as any shapediver definition should be optimized for speed, I am wonder if there is a faster way.
Thanks in advance.
Your method will work, but it might be faster using the attached script. You can modify the formula in the script, it is a little different than the one you wrote above:
grey_scale.gh (4.8 MB)
Adding my C# component that converts a bitmap to either grayscale (with variable contrast) or black/white (with variable threshold). No debugging, no guarantees that this works properly. Use on your own risk :smiley:
EDIT: Modified to work also with transparent PNG.
Will this work correctly in @shapediver environment?
GrayscaleBW.gh (66.9 KB)
  private void RunScript(object B, bool G, double F, ref object BW)
    author:   Petr Vacek (petrvacek.com)
    date:     24. 10. 2023
    version:  2
    Component.Description = "Converts bitmap image to black/white or grayscale";
    Component.Params.Input[0].Name = "Bitmap";
    Component.Params.Input[0].Description = "Input bitmap image.";
    Component.Params.Input[1].Name = "Grayscale toggle";
    Component.Params.Input[1].Description = "Set false for black/white and true for grayscale output.";
    Component.Params.Input[2].Name = "Factor";
    Component.Params.Input[2].Description = "Factor to influence the result";
    // create array of contrast values for colour matrix
    float[] contrastRow = new float[5];
    // image attributes object
    var imageAtts = new System.Drawing.Imaging.ImageAttributes();
    if (G == true) {
      // let user know which mode is active
      Component.Message = "Grayscale";
      // using F as a contrast factor
      float c = 2 * (float) F - 1;
      contrastRow[0] = c;
      contrastRow[1] = c;
      contrastRow[2] = c;
      contrastRow[3] = 0;
      contrastRow[4] = 1;
    } else {
      Component.Message = "Black & White";
      // using F factor as a B/W threshold
      imageAtts.SetThreshold((float) F);
      contrastRow[0] = 0;
      contrastRow[1] = 0;
      contrastRow[2] = 0;
      contrastRow[3] = 0;
      contrastRow[4] = 1;
    var grayscale_matrix = new float[][] {
      new float[] { 0.299f, 0.299f, 0.299f, 0, 0 },
      new float[] { 0.587f, 0.587f, 0.587f, 0, 0 },
      new float[] { 0.114f, 0.114f, 0.114f, 0, 0 },
      new float[] { 0,      0,      0,      1, 0 },
      contrastRow
    imageAtts.SetColorMatrix(new System.Drawing.Imaging.ColorMatrix(grayscale_matrix));
    if (B != null)
      Bitmap inputB = (Bitmap) B;
      Bitmap sourceImage = (Bitmap) inputB.Clone();
      int imgWidth = sourceImage.Width;
      int imgHeight = sourceImage.Height;
      Rectangle rc = new Rectangle(0, 0, imgWidth, imgHeight);
      // empty bitmap
      Bitmap bmp = new Bitmap(imgWidth, imgHeight, System.Drawing.Imaging.PixelFormat.Format32bppArgb);
      using (Graphics g = Graphics.FromImage(bmp))
        g.Clear(Color.White);
        g.DrawImage(sourceImage, rc, 0, 0, imgWidth, imgHeight, GraphicsUnit.Pixel, imageAtts);
      BW = bmp;
This is amazing. Would it be very hard to add transparency to the image, where there is white pixels?
I’m trying to make a logo upload option for a shpadiver definition and am struggling with transparency :frowning:
I managed to edit it with a little bit of research and chatgpt. thanks for the nice script.
bmp.MakeTransparent(Color.White);
added option to include specify color to make transparent and a range value
GrayscaleBW.gh (57.5 KB)
