Hi There,
In the following file, which i got here from the Forum, i am wat to do the following:
Change the Bitmap from colour to black and white, and then slect only the black coloured points.
I would appreciate any tips!
Globus.gh (812.8 KB)
Hi There,
Right click on the image sampler and make it enabled, that’s all there is to it. It’s just that it’s hard to see when some special components like this are disabled, to be honest it took me 5 minutes to find the problem myself.
Wha is it simple! Thanks!
Now I would like to access the individual colour values: Black & White.
I trie to do so with the “smaller than” component, but jet no succec…
Any ideas?
Thanks! I will need to study this to understands its logic.
Not sure I completely understand what you need, but if you use the brightness filter on that image it will gives a binary value, then just dispatch the points using this:
