Rewrite structure
Hello! Can someone tell me how this result can be obtained? I would be grateful for any help.
1.gh (12.1 KB)
just did this off quickly so there’s probably a better way of doing it in half as many components but it works.1.gh (11.4 KB)
Yes it fits, thanks!
One method would be to use the relative item component.
The following is a description/quote I saved from @DavidRutten, (I don’t remember which post/forum it came from).
Relative Tree items are specified using offsets in the data path and item index notation. Thus:
{0;0;+1}(-1)
means "get the item in the next branch that is one level behind me"
So if the notation for a specific item is:
{0;1;4}(3)
then the relative item will be found at:
{0;1;5}(2)
unless if there is no {5} and wrap is set to true, in which case the item will be found at:
{0;1;0}(2)
/end quote
path structure/notation can be a little hard to grasp at first, but this is one of the better descriptions I have heard, (hence…saving the description!)
attached file is in Rhino 6, but I’m almost certain it would work in 5 as well. The path notation MUST correspond with the incoming Tree to operate in (T input of Relative Item).
RelativeItem.gh (23.0 KB)
you can remove some compnents :slightly_smiling_face:
Wow that’s very cool!
