Hi Guys,
I generated a model from Rhino to Revit and the elevation is leveled to origin but want to push the model to the correct level and aligned from the link model.
Thanks
Hi Guys,
Thanks
Relocating or Changing the coordinates in Revit is the best way to do this (you don’t have to physically move anything)
Thanks Japhy, just a thought that this could be part of RIR as l just about complete setting up the model on the correct spot except for level.
Kind regards.
I’ll see what’s available in the Revit API but if I understand the workflow correctly the Revit UI is going to be more effective.
