Revit-like Trim/Extend?
Hello!
Is there a tool in Rhino that is similar to the “Trim/Extend to Corner”-tool in Revit?
It combines both trim and extend - you click on the line/curve-pieces that you want to keep, and that’s it. No matter if the lines/curves overlap or not.
There’s a lot in Revit that I find clumsy, but that one they got right.
Thanks!
Best regards
I use fillet with r=0 and join=true
Awesome!! Nice trick, thanks!
If I understand your question, the Connect command should do that.
