I have a set of pipes for which I want to find the path that each pipe traces in 3D space. For this question, I have attached the.gh file with two pipes from the list.
Reverse Engineering is most of the time a lot of trial + errror.
and working in small parts.
To get the center line, I would start something like this.
If the results are to grob, cut the mesh in smaller parts (overlapping) and join the curves after that.
NB: As soon you have some curve, redo the work using the curve + perp frames + mesh|plane to get better results.
Regards, Eef
