Extract center curves from 3D meshes
Recently I added this method to my compas_wood plugin:
#! python3
# venv: timber_connections
# r: wood-nano==0.2.0, compas-wood==2.4.0, compas==2.8.1, wood-rui==0.2.2
import Rhino
import Rhino.Input
import Rhino.DocObjects
from Rhino.Geometry import Plane
from typing import *
from wood_rui import wood_rui_globals, process_input, add_skeleton
from compas_wood.binding_rhino import beam_skeleton, mesh_skeleton
import System
def callback(selection: dict[str, any], name: str):
    # Just axis without radii
    if not selection["simplify"]:
        for mesh in selection["meshes"]:
            polylines = mesh_skeleton(mesh)
            for polyline in polylines:
                Rhino.RhinoDoc.ActiveDoc.Objects.AddPolyline(polyline)
        return
    # Try to simplify an axis
    polylines = []
    distances = []
    meshes = []
    transforms = []
        polyline = None
        polylines = []
        polyline, distance = beam_skeleton(
            mesh,
            selection["divisions"],
            selection["nearest_neighbors"],
            selection["extend_end"],
        polylines.append(polyline)
        distances.append(distance)
        meshes.append(mesh)
        # Add a small segement at the end of the polyline to provide orientation
        z_axis = polyline[polyline.Count - 1] - polyline[0]
        plane = Plane(polyline[polyline.Count - 1], z_axis)
        x_axis = plane.XAxis
        polyline.Add(polyline[polyline.Count - 1] + x_axis * 0.1)
        plane_xy = Plane.WorldXY
        plane = Plane(
            x_axis,
            Rhino.Geometry.Vector3d.CrossProduct(x_axis, z_axis),
        xform = Rhino.Geometry.Transform.PlaneToPlane(plane, plane_xy)
        transforms.append(xform)
    add_skeleton(polylines, "mesh_skeleton", distances, meshes, transforms)
if __name__ == "__main__":
    input_dict = {
        "meshes": ([], list[Rhino.Geometry.Mesh]),
        "simplify": (False, bool),
        "divisions": (10, int),
        "nearest_neighbors": (10, int),
        "extend_end": (True, bool),
    # Call the generalized input method with the dataset name and input dictionary
    process_input(input_dict, callback, hide_input=False)
This is method what you up to, since you dont care about straight timber beams made from scans. This method should work on your favorite editors rhino script editor, grasshopper or vscode:
from compas_wood.binding_rhino import mesh_skeleton
That is irrelated of the shape:
CGAL docs:
All the credits must be given to the smart people:
The initial implementation of this package is the result of the work of Xiang Gao during the 2013 season of the Google Summer of Code mentored by Andrea Tagliasacchi and Sébastien Loriot. It was finalized by Andreas Fabri and Sébastien Loriot.
At ibois long time ago I learnt how to wrap C++ methods to C# and Python since all the goodies are in the low level languages…
