I am working on a parametric hull modeling problem. I have created a function to read parameters as name value pair from a CSV file and store them in a Dictionary object. I want to call this function from my Main() subroutine and store the dictionary object into another variable. I would like to pass this Dictionary variable to another function for further calculations.
My function looks like:
Function readHullData(FilePath, FileName)
'Creating Dictionary object to store hull data
Dim objHull
Set objHull = CreateObject("Scripting.Dictionary")
'Reading parameters from file
Dim fso, MyFile,TextLine,LineData
Set fso = CreateObject("Scripting.FileSystemObject")
Set MyFile = fso.OpenTextFile(FilePath & FileName)
'Read from the file And storing the results.
Do While MyFile.AtEndOfStream <> True
TextLine = MyFile.ReadLine
LineData = Split(TextLine, ",")
'Storing hull data
objHull.Add LineData(0), LineData(1)
Loop
MyFile.Close
'Returning the hull data
Set readHullData = objHull
End Function
And the main function from where I want to call it looks like:
Option Explicit
'Script written by Amitava Guha
'Script version Tuesday, February 3, 2015 11:14:01 AM
Call Main()
Sub Main()
'Parameter file location
Dim FilePath,FileName
FilePath = "C:\Users\Data\"
FileName = "Matlab2Rhino.csv"
Dim objHull
'Set objHull = CreateObject("Scripting.Dictionary")
Set objHull = readHullData(FilePath, FileName)
End Sub
I am getting an error message Type mismatch: 'readHullData' .Can anyone tell me, how to set the function name to be an object. Also for the next stage, how to send a Dictionary object to another function. I tried the method given here, but didn’t work.
Thank you for your help.
Best,
Amitava
Dont know if it solves the problem but you can try to remove the Set part of:
So you get
Also… is the function and the main function located in the same script?
Thank you for your response. However, this method did not solve the problem. Getting error message "Wrong number of arguments or invalid property assignment".
For the time being, I have all my functions in one file. I would like to know how I can put them separately.
I am attaching my script and the data file here. You need to rename .txt to .csv and change the path in script to make it run.
Main.rvb (4.4 KB) Matlab2Rhino.txt (592 Bytes)
I dont know why it doesnt work. If I copy the functions code and put it in the Main it works.
This is another solution. Make the objHull a script variable
Option Explicit
Call Main()
Dim objHull
Sub Main()
'Home Computer
'FilePath = "C:\Users\Amitava\Dropbox\Doctor of Philosophy\Optimization\Project\Attempt_2\Data\"
'FileName = "Matlab2Rhino.csv"
'Office Computer
FilePath = "C:\Users\Techmed\Desktop\"
Test FilePath, FileName
'Call readHullData(FilePath, FileName)
Call generateHull()
End Sub
'Function to read CSV file and store hull data
Sub Test(FilePath, FileName)
'Storing hull data
Loop
MyFile.Close
'Test for stored data (can be commented)
Dim arrKeys,arrItems
arrKeys = objHull.Keys
arrItems = objHull.Items
Rhino.Print(arrKeys(0))
Rhino.Print(arrItems(0))
End Sub
'Function to generate and save the hull surface
Function generateHull()
' Start a new model,
Rhino.Command "-_New n"
'Set document properties
Rhino.Command "-_DocumentProperties u u e n _enter _enter"
'Create a Ship hull
Rhino.Command "-_OrcaCreateShipHull LengthOnDeck 160" + _
" BeamOnDeck 25" + _
" BeamAtTransom 0.6" + _
" BowDepth 18" + _
" TransomDepth 18" + _
" Draft 8" + _
" TransomHeight 8" + _
" DeckTaperAft 0.4" + _
" DeckTaperFwd 0.4" + _
" KeelRisePt 0.7" + _
" KeelRiseRateFwd 0.3" + _
" KeelRiseRateAft 0.2" + _
" StemRake 30" + _
" TransomRake -10" + _
" DeadriseMid 0" + _
" DeadriseAft 0" + _
" DeadriseFwd 0.1" + _
" SideSlopeMid 0" + _
" SideSlopeAft 0.1" + _
" SideSlopeFwd 0.9" + _
" SectionTightnessMid 0.6" + _
" SectionTightnessAft 0.8" + _
" SectionTightnessFwd 0.67" + _
" FlareMid 0" + _
" FlareFwd 0.6" + _
" FlareAft 0" + _
" StationMaxArea 0.5" + _
" BowRounding 0.2" + _
" StemCurvature 0" + _
" ForefootShape 0.6" + _
" Prismatic 0.25" + _
" SheerHeight 1" + _
" SheerHeightPos 0.5" + _
" NumRows 9" + _
" NumCols 12" + _
" _enter"
'Creating other half
Call SelectModelGeometry
Rhino.Command "-_Mirror p 0,0,0 1,0,0 1,0,1 _enter"
'Rotating about z-axis so the bow points towards +ve x-axis
Rhino.Command "-_Rotate 0,0,0 180 _enter"
'Translating forward to have midship at origin
Rhino.Command "-_Move 0,0,0 80,0,0"
' Export the selected objects
Dim strPath,strFile
strPath = "C:\Users\Amitava\Dropbox\Doctor of Philosophy\Optimization\Project\Attempt_2\Data\Model.igs"
strFile = strPath
strFile = Replace(strFile, ".3dm", "_" & "Test" & ".igs")
Rhino.Print(strFile)
'Rhino.Command "-_Export " & strFile, 0
'Rhino.Command "-_Export"
Rhino.Print("Done!")
End Function
' Subroutine to select all surfaces, polysurfaces, and meshes in the model
Sub SelectModelGeometry()
' Select all surface, polysurface And mesh objects
Rhino.Command "-_SelSrf"
Rhino.Command "-_SelPolySrf"
Rhino.Command "-_SelMesh"
End Sub
Decare it on the top. This works
I changed to FilePath though… Dont know the original one.
Thank you. Defining objHull as a script variable worked. Is there a way to write the functions in separate files instead of making one long script file?
You can add an alias to a script so it is usable as a normal rhino command. After this you can use:
rhino.command yourcommandname, true
to run that rhinoscript.
