Hi
Someone has an example about how to return values from Mouse Callback? For example onMouseUp return something?
I still have my problem with Delegate, handler Event and so on.
Thanks
Paolo
Hi
Thanks
Paolo
Hi @flecheria,
Here is a simple example:
public class TestMouseCallback : Rhino.UI.MouseCallback
protected override void OnMouseMove(Rhino.UI.MouseCallbackEventArgs e)
// TODO...
base.OnMouseMove(e);
protected override void OnMouseUp(Rhino.UI.MouseCallbackEventArgs e)
// TODO...
base.OnMouseUp(e);
var callback = new TestMouseCallback { Enabled = true };
As you can see, the event handlers do not return a value. But you can certainly call functions within the handler.
– Dale
thanks Dale! Maybe this is the time that I finally master the Event in C#!
