Hi guys,
I am trying to retreive a List of data through all my variable parameters which have their Access
set to GH_ParamAccess.list
All variable parameters are of type Param_GenericObject
because they will receive as input any type of data ( meshes, strings, points, vectors…etc)
I have been sucessfull in the past on retreiving data from these variable parameters when their Access
is set to GH_ParamAccess.item
. But now I am having some trouble when they are set to List
I have ran through the code in debug mode and I always have null values, after I call DA.GetDataList()
on the corresponding variable parameter.
I hope that some code and these two images can help to illustrate my point more explicitly.
Image 1: variable component highlighted in blue and a List<Point3d>
as input
Image 2: Showing null values in VS after calling DA.GetDataList()
Code from Solve Instance ( just to give some backgorund):
protected override void SolveInstance(IGH_DataAccess DA)
// Gather data from normal inputs
bool _send = false;
string _id = "";
DA.GetData(0, ref _send);
DA.GetData(1, ref _id);
// Start gathering data from variable parameters
int threshold = 0;
int inputCount = 0;
for (int i = 0; i < Params.Input.Count; i++)
if (Params.Input[i].Name != "Data") threshold++;
if (Params.Input[i].Name == "Data") inputCount++;
List<int> indexes = new List<int>();
DataContainer dc = new DataContainer(inputCount);
List<DataContainerFactory> _dataContainers = new List<DataContainerFactory>();
// Iterate through params and find ZUI parameters (if there are any)
if (i > threshold - 1)
// Set temp data
int count = Params.Input[i].VolatileDataCount;
IParaData[] s = new IParaData [count];
_dataContainers.Add(new DataContainerFactory(s));
indexes.Add(i);
// Retrieve data from ZUI parameters ( if there are any)
// and assign it to _dataContainers
for (int i = 0; i < _dataContainers.Count; i++)
// Here is were the data should actually get collected... but it does not
DA.GetDataList(indexes[i], _dataContainers[i].data.ToList());
///*** ALL ITEMS IN DATA CONTAINERS ARE ALWAYS NULL EVEN THOUGH DA.GETDATALIST
///*** WAS CALLED ON EVERY VARIABLE PARAMETER AND COLLECTED THE DATA
IParaData[] pp = new IParaData[_dataContainers[i].data.Length];
for (int j = 0; j < _dataContainers[i].data.Length; j++)
// for such reason this condition in particular is not getting executed
// because a Point3d is obviously not a null. But the same would hold true
// if it were a Polyline or any other type.
if (_dataContainers[i].data[j] is Point3d p)
pp[j] = new Para_Point3d(p.X, p.Y, p.Z);
else if(_dataContainers[i].data[j] is Polyline)
pp[j] = new Para_Polyline<Polyline>(_dataContainers[i].data[j] as Polyline);
/// So on and so forth....
dc.Container[i] = pp;
PS: sorry for the messy code, I am putting together some stuff rather quickly.
Any ideas would be very helpful !
