Request: Import under current layer
Request for an option added to Import, or a new command.
I need to import .3dm files under the current layer with the layers of the layer structure of the imported file as sub-layers.
Example: File which is open has layer structure:
File to be imported has layer structure:
Result after importing file:
Ultimately I want to import multiple files, and have the contents of each under a different layer:
Hi David,
Is this a one off or an ongoing requirement? In the absence of any automation, the best way to do this manually is to add the titular boat layer to its individual file, drag all the pre-existing layers to be subordinate under it, save the file, then import it into the destination. This avoids the risk of layer merging on import.
Regards
Jeremy
Ongoing need so either an option to Import or a new command is desired. I’ll amend the subject and my first post.
