Replace an array of point objects [C++]
Hello all,
In my plugin I add a set of point objects like this
CRhinoPointObject** point_object_array = new CRhinoPointObject*[4];
for (int i = 0; i < 4; i++) {
	point_object_array[i] = new CRhinoPointObject();
	point_object_array[i]->SetPoint( array[i] );
	context.m_doc.AddObject(point_object_array[i]);
Note that array is an ON_3dPointArray of size 4. After some changes (of array, and attributes) I need to replace it, trying this
CRhinoPointObject** new_point_object_array = new CRhinoPointObject*[4];
	new_point_object_array[i] = new CRhinoPointObject();
	new_point_object_array[i]->SetPoint( array[i] );
	context.m_doc.ReplaceObject(point_object_array[i], new_point_object_array[i]);
context.m_doc.Redraw();
but it doesn’t work… Maybe because of the **pointer? Is there a workaround for this?
Many thanks!
Pablo
Hi Pablo,
Tracking runtime objects by their pointer is never a good idea. Better to track runtime objects by their model id (UUID).
See if the attached sample code gives you any ideas.
cmdTestPablo.cpp (2.0 KB)
– Dale
Hi Dale,
This example is great! Just one question: when you assign the model id
	m_points[i] = ON_3dPoint((double)i, (double)i, 0.0);
	m_object_ids[i] = ON_nil_uuid;
You are assigning the same id to all the points, right? The number ON_nil_uuid. Isn’t there a conflict here?
Is this topic of the UUID explained somewhere in the guides?
Thanks again,
Pablo
Hi Pablo,
Yes.
ON_nil_uuid is a null (e.g. empty or zero) UUID. Rhino objects do not have null UUIDs. Thus, ON_nil_uuid is used to indicate that the object does not exist, in this context.
This is why the sample checks for null UUID and, if so, adds a new object. If the UUID is not null, then is assumed that the object already exists. Thus, the code replaced the geometry.
Make sense?
– Dale
Ajá! Got it :smiley: This ModelObjectId() method is great!
Thanks for the sample,
Pablo
