I not sure whether this is possible or dose it make any sense!
I have a original 4 untrimmed surface which I am trying trying to repeat as per the Item No but unfortunately at the moment it is copying the surface for example 0 & 1st item twice
Hi Randeep,
From the little I see, the numbers you feed into list item are repeated. that’s why you get two times each surface.
anyway, I would advice you to read this post and follow the instructions.
(mainly the "upload file " part)
cheers
