Repairing surface isocurve
isocurve.gh (1.3 MB)
hello everyone please i am trying to use lunchbox on this surface but i am getting this anomaly, please how do i repair the isocurve while maintaining the exact surface naked edges.
Hello
you can rebuild your surface and using a Graph Mapper to have different UV points
isocurve_LD.gh (1.3 MB)
There is also a third method that could use tween curves, a bit more complex. and it uses Nautilus plugin
Here the result between tween and rebuild surface
here I extract 2 curves that are the opposite sides of your surface.
It could be also the 2 others side (on the floor)
I put a weight of 0 on one curve and 1.001(to avoid some problems) on the other curve.
Then I use a tool to smooth the weight (like if it was temperature)
I get this
Then I get the iso curves
that I join (it is important to have a single curve for each iso curve and join curve doesn’t give a single curve)
Curve are oriented and a loft is done
isocurve_LD3.gh (1.3 MB)
Tween
Rebuild surface
Thanks a lot. this is really helpful.
thank you
