Rendering Rhino Vs Toucan
I can apply a texture with the Material panel> Object> Texture, instead I can not do it with Toucan Material, if I try to apply a new material with the same texture.
In attachment you see the deck with Material> Object> Texture and the two trapezes with the Toucan material that does not appear.
thanks
Giuseppe
i think rendering in mac rhino at the current state is sort of-
if you find something that works for you, great! :smile:
i believe there’s some work happening with the renderer lately and it’s likely we’ll see some changes prior to release at which point, then, you should really attempt to figure it out… in it’s current state, we have rendering capabilities but it’s a bit of this from there and a bit of that from here with not much of a central logic tying it all together.
(that said, i really only read your title to say all of that… i’ll read the rest in a bit and comment if i have anything helpful to add)
