When rendering a simple scene with Cycles and ProRender, the differences seem to be pretty large, as can be seen in the image below:
I did not change any parameters, same environment, same gamma value etc.
Is there an inherent reason, why proRender looks so much different? Is there a setting, that I have to tweak in order to get similar results, or is this just a natural byproduct of using different render engines?
