Render meshes low poly Rhino x Twin Motion
Any geometry with a smooth curve appears broken or low poly count on the viewports and subsequently on the Twinmotion Window. The geometry’s true and intended curve exists however does not display as modelled. Any fixes??
Tried:
Deleting, pasting back in
Cutting, pasting back in
Hi Edwin -
Please post a sample 3dm file that we can use to troubleshoot this issue.
Re-opened the file this morning and it seems to be fine now, however the simplified geometries aren’t as bad as before they still persist on the the curved architrave that has been modelled. However this is a frequent problem that seems to come up when modelling the smooth geometries and would like to know a solution moving forward!
Images below display the extent of the issue from yesterday.
Model below displays what appears to be the rectified issue.
RHINO QUESTION 01.3dm (771.9 KB)
Thank you!
Hi Edwin -
That part makes me think that you are looking at issues with the display meshes of objects. They are generated based on settings in the Document Properties and can be overridden per object in the Object Properties. See Rhino Mesh Settings [McNeel Wiki]
That part is weird, though, as the document settings don’t change by themselves…
