In Rhino 8 it appears to be a default that selecting a render color for an object will apply that color to all item in that layer. I want to assign individual object colors for diagraming like in 7. Does anyone know what to do?
Hi, @jgosser1. I am making a few assumptions here: 1. You said render color which I am taking to mean material (because it would change the color in a Rendered display mode. 2. You want to override a layer’s material with a per object material. In the attached screenshot and file, I created 3 boxes, all on the same layer, then manually changed the first 2 material settings in the 2nd tab of the Properties panel. Try doing so with the 3rd box. Hope that helps!
Object-based materials v8.3dm (328.5 KB)
