How can I use OpenNURBS to create a NURBS surface and render it ? That means which libraries -functions can I use.
Do you want to do this outside of Rhino, or in Rhino as a plug-in?
Outside of Rhino.
Outside of Rhino the OpenNURBS SDK is primarily for reading and writing the .3dm file format. You should be able to create a NURBS surface indeed, but you won’t have any rendering facilities, nor any of the geometry operations.
I just use OpenNURBS for secondary development.So can I use the header files ‘‘opennurbs_gl.h’’ and ‘‘opennurbs.h’’ to render the NURBS surface in an independent window? Besides,any other header files necessary?
@dale can you help here?
