I am trying to turn off all clipping in the active viewport via this Grasshopper C# component:
private void RunScript(bool Run, object y, ref object A)
// Only modify clipping when Run is enabled
//if (!Run) return;
// Find and clear any active clipping of current view
var view = RhinoDoc.ActiveDoc.Views.ActiveView;
var viewport = view.ActiveViewport;
var viewid = view.ActiveViewportID;
Rhino.DocObjects.RhinoObject[] planes = RhinoDoc.ActiveDoc.Objects.FindByObjectType(Rhino.DocObjects.ObjectType.ClipPlane);
foreach (var plane in planes) {
// RemoveClipViewport does nothing if plane not clipping given view
var cplane = (Rhino.DocObjects.ClippingPlaneObject) plane;
A = cplane.RemoveClipViewport(viewport, true);
Rhino.DocObjects.ClippingPlaneObject[] planes = RhinoDoc.ActiveDoc.Objects.FindClippingPlanesForViewport(viewport);
A = plane.RemoveClipViewport(viewport, true);
//A = plane.ClippingPlaneGeometry.RemoveClipViewportId(viewid);
//A = plane.CommitChanges();
Here, viewport
is correctly referring to the active viewport (Perspective, Top, etc.), and planes
correctly extracts the single clipping plane I have in the model. However, even though RemoveClipViewport
returns true, my model remains clipped in the viewport. Any ideas what is going wrong or are there alternative methods for doing this?
Edit: I should mention the commented lines are other attempts at removing the clipping, none of which worked. The Run
parameter check is commented out for debugging.
