Hello, I would like to make a fillet between surfaces, but the problem is that when I select my surface, Rhino only selects a parcel of it even though it is well joined. It would be helpful if you could help me get my surface to the same seamless appearance as in photo 5. Thanks in advance for your help.
Hi Melvin,
I’m guessing you are trying to use _FilletSrf. Instead, use _FilletEdge which will allow you to select the entire edge.
If for some reason you can’t get that to work, select the object, _Export the selection as a new .3dm file and post that file here so we can see where the problem lies.
HTH
Jeremy
Thank you very much, this helps me a lot.
Very good day.
