Hi All,
I have seen this topic come up a few times, the removal of empty list items, and why cleaning a tree full of empty list items doesn’t remove a the branch.
For my own uses, i have put together a little cluster that allows three options. Following David Ruttens post on the topic some time ago - I will refer to list items as Twigs:
Options include:
- Remove empty twigs from a tree;
- Remove empty twigs AND resulting empty branches;
- Remove Branches made of empty Twigs (will retain empty twigs in a branch which where at least 1 twig is not empty).
I have attached the cluster below:
Remove Empty Twigs, or branches of Empty Twigs…gh (11.5 KB)
I haven’t extensively tested this, but its a simple cluster and should be easy enough to edit.
Note: The script uses text length to cull data, will also remove Null values because of the way its set up.
Possible to retain the null values with some edits - which i might build in as an option in future.
Hope its of use to someone in future
