Jack_R
(Jack)
March 19, 2019, 10:36am
1
I am using the clean tree component but somehow it isn’t removing the branches. Am I doing something wrong?
I even set all the booleans to True
Is the component supposed to function differently or is there some other component that I should be using?
clean tree.gh (9.2 KB)
Jack_R
(Jack)
March 19, 2019, 10:42am
4
I have already tried this and it doesn’t seem to work
He wants to remove empty, but the way the data is presented empty is actually a text, so the branch is not really empty.
Jack_R
(Jack)
March 19, 2019, 10:44am
6
Thank you, this will work for now.
But is there any way to avoid the red component?
And would it still function if there was data other than a number?
Maybe, we have to know how that list was generated… unless it is a top secret, then lord knows
Jack_R
(Jack)
March 19, 2019, 10:48am
8
Haha, the list was in fact an empty text. I generated the ‘empties’ using ‘replace item’ component without providing any replacement items as list.
Should I change any parameters there to make sure that it works with clean tree?
you can use this because all empty’s have the same index 0
and this ; cull index 0 than clean the tree from empty
Jack_R
(Jack)
March 19, 2019, 10:56am
10
Thank you, this will work for now. Is there anything else I can do to remove ‘empty’ text instead of the ‘’ parameter?
i don’t know maybe when you internalised data the empty’s converted to texts as David said
Hi…I am struggling with this node as well…
I got it working for tree
it is working for list null;
but does not work for a list empty …
is it a bug ? or there is another node for a list?
HS_Kim
October 15, 2020, 12:05pm
13
I don’t think it’s a bug and I have no idea about another component, but you could do something like this…
Remove Empty_re.gh (13.7 KB)
I would simply graft the Tree input and then shift path the Tree output.
In that way you are dealing with the same model as in the first picture.
The “empty” in the component means a list with zero items. The “empty” in the panel means a string with no characters. They are not the same kind of empty.
You can clean up your list by removing items with zero text length.
{0;0}:zero items list
{0;3}:zero length text
