Hi Guy, I have some Curves on difference layer and these curve are overlap In my file Layer Beam need to be trim or remove overlap lines by layer Column and wall
Thanks All Remove overlap curves in difference layer.3dm (324.9 KB) Remove overlap curves in difference layer.gh (9.3 KB)
Sel Dup will remove any exact overlaps in Rhino. This would best be handled there in this instance I believe.
Hi, I trying use Sel Dup it not done in my file can you see Column and wall layer overlap Beam layer Thanks
Hi, I just make video manually trim in Rhino
