News
Facade Pressures
Run a VWT simulation and use the results to calculate the pressure coefficients. The coefficients can later be used in an EnergyPlus calculation.
Read more about how to work with pressure coefficients on Compute here
Demo
Try out the demo by downloading it here
Mesh Independence Study
It is now possible to run automated mesh independence studies on Compute. The study can be used to determine how dependent your simulation results are on the underlying mesh.
Read more about how to do mesh independence studies on Compute here
Demo
Webhooks
Run a VWT simulation and use Compute’s built in webhook to ping a remote url.
Read more about it here
Demo
Advanced Probing
Run a VWT simulation and probe the inlet velocity at each time step.
Read more about how to work with this advanced version of probing here
Demo
Demos
All of our demos are available here
BONUS it is now possible to filter the tutorials based on different tags!
Plugin Updates
We have released multiple versions of the Compute Grasshopper plugin with various improvements and fixes.
- Pressure Coefficient component has been added for working with facade pressures
- The LoadProbeResult component have been updated, so now it takes in a MeshPath and not a mesh.
The latest version of the plugin is 2021.9.0
You can update through Food4Rhino or use the PackageManager in Rhino 7, or TestPackageManager in Rhino 6
