Anyone have an idea how to suppress this section of the definition (cull pattern + shortest list match. if possible). What kind of panel description I can input in the relative item operation input to count item by 2 instead of one … ( so I can remove the cull pattern part).
Those “selection rules” works with “Split tree” component. If you have 2 different trees you could use the same splitting mask and pick the “positive” output from one and the “negative” from the other…
… but you are working with lists, not trees… i’m not quite sure what are you doing…
You are using components made for trees … with lists.
Use dispatch.
