Hi, I am using Grasshopper Region Union Component to get the envelope contour of a list of overlapping rectangles, it works but when reaching a high number of rectangles, it doesn’t work anymore.
Any idea about what’s going on or did I miss something with Region union Syntax?
I couldn’t open it either and gave up - then opened it with solver turned off, disconnected all curves from the region union, created simple quads from the curves, joined the mesh, and attempted mesh shadow - it took 35 seconds and produced nothing - however it should?
I tried both solutions suggested by Laurent as I already said both work perfectly but one of the two Union tips is fuzzy as shown here after.
The desired clean tip is the one with Rhino Command “CurveBoolean”, but another bug with Rhino Command “CurveBoolean” is that the result seam good but it’s made of two open polylines instead of one closed and overlapping as shown hereafter.
my problem with Region Union component is when the intersection failed, the given result is null, it would be better if it returns the input geometries.
