Reference Rhino Notes Tab to Grasshopper
Hi All,
Wondering if anyone has experience with referencing user text generated in the notes tab of rhino into grasshopper. A reasonable amount of googling didn’t turn up much, so I’m hoping any pros out there can assist.
Thanks in advance
Hi Brett
Googling will get you nowhere.
Some time ago I needed it desperately and I turned for help on this forum and I got the solution which I am sharing with you.
find_notes2.gh (9.1 KB)
Awesome!
While looking into the code of your script - I was researching some of the commands and found that this is another solution to read notes for the current doc:
Seaching the forum for ‘notes’, you’ll find this…
Thanks Martin - I may have been using weak search terms as i was mostly getting more general results from my searches. Will focus on being more specific next time :stuck_out_tongue: Thanks!
How to retrieve notes that contains multiple lines to create a list?
I replaced the unicode character 13 (line feed) and 10 (carriage return) with an asterisk and used the asterisk to split the text.
a = chr(int(x)+y)
