_ReduceMesh preview issues
two issues which could be solved:
  • If the Preview is calculated and the user like it and press OK, than this preview could be direct used instead to calculated it again. I hope this is possible and time could be saved.
  • Please add a shaded preview option which allow to see the shape. Nice would be if the mesh could be light overlayed. Attached a raw example mixed in Photoshop. So the user could better see how details are kept.
  • Also very useful would be to simple switch between an original and reduced shaded preview. So, the user could see jumps at the model, where big shape changes are added.
-Micha
Hi Micha, thanks, I’ll add this to the pile.
RH-62170 ReduceMesh: Use the preview mesh
RH-62171 ReduceMesh: Shaded preview
RH-62172 ReduceMesh: Toggle shaded preview
RH-62170 is fixed in Rhino 8 Service Release 7 Release Candidate
…and RH-62170 is fixed in Rhino 8 Service Release 7 too.
RH-62171 is fixed in Rhino BETA
RH-62172 is fixed in Rhino BETA
