The ReduceMesh dialog is not dark when Rhino is in Dark Mode:
I saw somewhere there are adjustments to the dark mode, maybe this is the reason .
And a next light dialog:
Also see the typo.
And it is not translated @Joachim_Kuntz.
Nonsense.
The dialog is from byRhinoGadget.
I don’t think it is because of an adjustment, I think it’s an oversight.
Cosmetics.
Hi Charles,
Is this dialog from core Rhino? I searched our code for “couunt” and cannot find anything. Also, the only place the string “Create new object on current layer” shows up in our code is in the Rebuild command and the dialog is quite different from what you show there.
Tim
Hello Tim
I think so.
Tim, you are right.
RH-83266 is fixed in Rhino 8 Service Release 11 Release Candidate
