I have a simple question: how to change the default drawing plane of 2d rectangle corner to corner ? (without using the option 3Point every time)
Change your cplane with the cplane command. You can also save the cplanes using namedcplanes. Each viewport will keep the last cplane until you change it again.
THANK YOU @ Dharman !
Also note that with the OneView
command, you can have the CPlane change on-the-fly just by modifying the view.
