Correct me if I am wrong or have not noticed a change in Rhino but in some cases I will rebuild a surface with its current UV and degree settings to clean up the points or make them uniform. However I am noticing now that the rebuild command will keep the points non uniform. Unless I make a change to my UV settings where rhino will then make my points uniform.
Hi Tommy - rather than Rebuild for this, you might try
MakeUniform (note this does not apply to the points but the knots, however it makes the surface more tractable for point editing)
followed by
MoveUVN - select the interior points (trick: testSelUVRectangle - now in V6 as SelControlPointRegion, btw) and use the Smoothing sliders to relax the points.
Does this help for what you want to do? Can you post or send me the starting surface that shows the Rebuild thing you asked about?
Hi Tommy - I’ll see if I can dig up a thread from a few weeks or months ago there there was a similar question and the explanation from the developer - it might apply here, I am not sure… hold on a bit…
(Mikko’s comment - it is not exactly the same situation though)
I do see that extracting a short direction iso from your surface and rebuilding to the same degree and point count evens things out more than rebuilding the surface does at that same location… I’ll poke some more.
