Rebuild curve
Hi :
it’s a simple question: why the maximum deviation does not show up when I rebuild a curve ?
did you press preview ?
if this does not help, please upload your file with the curve in question - and also post your systeminfo. (command _systemInfo)
if you need a workaround:
_crvDeviation
will allow you to measure the deviation after the rebuild curve was created as a copy.
